Long drive if he's coming all the way from Newfoundland.
Unless he's driving up from Saint John...... in which case it would be significantly shorter.
Every road in the local area here is closed, OPP has even pulled patrols off the road in four detachments, but we've still got power.
Got my generator staged and ready just in case, at least you've got that Marc !!!
Lol! ?
I guess he’s coming from neither.
I made up a hybrid name it looks like.
I know enough to not have used the hyphen and “s” to avoid making it “St-John’s”.
But I have to admit, I don’t need to write Saint John in any communication very often, and never had anyone point it out so eloquently before.
I won’t forget now. ?
Yes thankful for the generator, and the two oil radiant space heaters I had.
As stated above, this was first time off the grid in winter since built the house.
Turns out the space heaters did the lion’s share of the work.
The one heat pump I have on the generator circuit kept defaulting to fail safe mode.
Even with trying to reset it by turning the breaker off and on.
Now that we’re back on the grid, it’s working fine with no issues.
So I’m no electrical whiz but thinking there’s some issue with the generator power vs grid power.
Whatever it is the heat pump doesn’t like it.
Thinking of putting that heat pump back on main panel and use space from that breaker to regain my kitchen outlets and microwave, and possibly outlets in garage and wifi while on generator power.
Get another one of those oil radiant heaters to compensate for losing the heat pump.
