great white
Grumpy Old Fart
Strut pics:
great white;n9891 said:Well, got the LH camber/caster plate installed.
Easy to change the settings, in fact almost too easy. It's just open slots and needs a fine touch when adjusting and it's a fine line between the bolts being tight enough to move yet not so loose that it looses it's settings.
+6 Degrees caster looks to be about the maximum (as measured by an angle gauge on the strut). For street driving I'm going to start with +4.5 caster and see how it goes. Autocross will be around +5 to +5.5, which is close to the max these plates will give anyways.
Looks like - 2 or so is the max negative camber (on the same angle gauge). With -2 ish camber, the tires are tucked well in under the stretched wheel wells. I'll probably run -1 on the street and drop to a full -2 to -2.5 when (if) autocrossing.
I have pics, but photobucket is being a pain right now so I'll have to post them later.
The front end has dropped dramatically with the sn95 spindles, sn95 arms and the trashed v6 springs. I can only hope it comes back up when I install the Mach 1 springs. I believe it will since the v6 springs are a super mushy rate and it's missing a ha;f coil (broken off).
I may have a bump steer issue, but it's hard to tell looking at the geometry as it sits. The ball joint isn't home in the spindle (only loosely assembled as I'm waiting for new ones to arrive) and the drop from the V6 springs are throwing it all out of whack.
Got the tie rods ends on also. Looks like I may have to nip 1/4 to 2" off the inner tie rod ends. The outers bottom out and it looks somewhat toed out still. I need to get both sides together and take some measurements to know for sure. Clipping a little off the inner tie rods to get something to fit is far preferable to using something like a Taurus inner tie rod 9common for rack swaps on a fox). Mustang tie rods you'll be able to get at any corner parts house until the world stops turning, where the Taurus is only going to get harder and harder to get parts. Except for a couple SVO Taurus's, they're throw away cars. aftermarket suppliers will stop making parts for them as they begin to drop off the parts sales leader boards.
This weekend is pretty much a "stop" on working on the car. Tomorrow the bike goes down to Dartmouth and I'm headed out to lantz to pick up a couple inner fender liners and hopefully a dead pedal. Sunday I have to clean the garage up. It's been non stop thrash for a while and it's turned into one heck of a "S-pit".
I almost want to scream when I walk in it's sooooo messy......![]()
