OK. Slight course change here.
Right now, I've got the 7.5 axle in it with the SN95 28 spline axle shafts and disc brakes.
This weekend, I'm picking up a fox 8.8 axle housing. bare, nothing in it.
I've found an explorer 8.8 with 3.73 gears and trac lok and here is where things get a little "wonky".
The explorer differential is 31 spline. So while it will bolt into the fox 8.8, the 28 spline shafts won't work with it. The 31 spline axles are also a larger diameter than the 29 spline shafts, so the wheel bearing for the fox won't work with the explorer 31 spline shafts either. There are no "conversion bearings" available in the correct dimensions either. The actual housing tube is also a larger diameter on the explorer axle.
The explorer axle has different brackets so it won't bolt into the fox. Even if it did, the center section is offset 2" so one axle tube is too long, one is too short. Additionally, the upper control arm mounts for the fox aren't even cast into the explorer center section housing.
So, my options as I see them:
1. explorer differential into the fox housing, order some aftermarket 31 spline axle shafts that fit the fox housing.
Pro: quick and easy, drops right in with nothing more than a socket set and a few measuring tools. I get a 31 spline trac lok carrier and axle shafts for added strength over the 29 spline.
Con: Fox 31 spline axle shafts don't come cheap and if I ever need one again I have to order them out of the states and wait.
2. Explorer diff into fox housing. Use two passenger side explorer OEM axles (same length as the Sn95 axle shafts) and cut/weld the explorer tube ends on the fox axle (in order to use the bigger explorer wheel bearing for the bigger shafts).
Pro: just my time for setup and labor. OEM parts except for the fox tube alterations. I get 31 spline shafts, larger wheel bearings and seals and bearings are same as OEM (can get them anywhere)
Con: welding tube ends on can be tricky on the thin ford axle tubes. Warpage can lead to toe and caster problems. welding larger tubes on to smaller tubes can also be tricky and could compromise strength if done poorly.
3. Alter the Explorer axle to fit the fox.
Pro: all OEM stuff except the tube lengths.
Con: Driver side tube need to be shortened, lower control arm brackets need to be torched off the fox and welded on the explorer, need to get the pinion angle correct, possibility of tube warpage still need to source another passenger side explorer axle shaft and the explorer axle doesn't have the top 2 fox mounts so I'd need to install a panahard bar and torque arm just to move the car around under it's own power (time and $$$ is the limiting factor as the car will eventually get a panhard bar and torque arm anyways).
Option 1 seems easiest, but most expensive. Option 2 seems most "frugal", but higher chance to mess it up. Option 3 sounds expensive and a nightmare to complete correctly.
Right now I'm thinking option 2 sounds best for my particular situation. I have to wait until I get everything side by side and do some measurements to know for sure.
Either way, the explorer axle is too good a deal to pass up and a 31 spline rear axle will put an end to any concerns about the rear end whether I'm playing at autocross style events, drag racing or just a hard pop on the street. Picking up the explorer axle is worth it even if all I get out of it is the ring and pinion and some hardware (bolts and such).
Right now, taking int o account the fuel I'm going to spend to gather it all up, I could potentially have a 31 spline fox axle for 150-200 bucks.
That's pretty darned good!
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
