[h=1]Drive or Restore: 1966 Ford Mustang Coupe[/h]
Adam Clarke
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/08\/1966-Ford-Mustang-Coupe-1-e1567312029610-630x390.jpg"}[/IMG2]
After spending the past 31-years in the care of the same family, the time has come for this 1966 Mustang to move on to greener pastures. It is going to need a bit of work to return it to its best, but when a running, driving 1st generation Mustang project car comes along in a No Reserve auction, it is definitely worth a look. It is located in Englewood, New Jersey, and listed for sale here on eBay. Bidding has now reached $4,400, and remember those magic words…No Reserve.
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/08\/1966-Ford-Mustang-Coupe-2-e1567312070727-630x390.jpg"}[/IMG2]
There is no hiding the fact that the Mustang has some rust issues that will need to be addressed in the very near future. It has impacted many of the usual lower extremities of the car, including the lower quarter panels, bottom corners of the doors, and the lower fenders. There is also some significant rust visible in the cowl region of the engine bay when the hood is lifted. The owner says that there is some rust present in the floors, but that this could be easily patched. The Mustang received a repaint back in 1988, and this brought a color change. It isn’t clear what the Mustang’s original color was, but this shade of Silver Blue doesn’t look too bad. The external trim and chrome look to be in good condition, as does the black vinyl top.
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/08\/1966-Ford-Mustang-Coupe-3-630x390.jpg"}[/IMG2]
The interior of the Mustang presents reasonably well and is certainly clean enough to serve as a daily driver. There is some puckering on the door trims, but things generally aren’t too bad. The Mustang has been fitted with an aftermarket radio/cassette player, while there are now also a set of speakers mounted in the rear parcel tray. Otherwise, the interior is largely original, and the inclusion of air conditioning is a bit of a bonus.
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/08\/1966-Ford-Mustang-Coupe-4-e1567312134931-630x390.jpg"}[/IMG2]
Under the hood of the Mustang is a 289ci V8, which is hooked to an automatic transmission. It isn’t clear which version of the 289 this is, but if the engine is original, then you should be able to bank on having at least 200hp at your disposal. This is an area of the car where there are some positives to be found, as the engine has always been properly maintained. This means that it starts and runs well and that the car drives really nicely. It would appear that apart from some cleaning and detailing, there is little that will need to be done to the engine of this car.
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/08\/1966-Ford-Mustang-Coupe-5-e1567312174782-630x390.jpg"}[/IMG2]
I’m quite torn by this Mustang. Since I was a young boy, this is pretty much the Mustang that I dreamed of owning. This one shows a fair amount of promise, but it is also exhibiting some pretty worrying rust issues as well. The rust in the cowl is the biggest concern because it would be imperative that this is fixed properly if the structural integrity of the car is to be maintained. What do you think? Is this a viable project car, or is the rust a bit of a worry?
More: Ford / Mustang
SHARETWEETE
SHARETWEETE
