[h=1]Racer Replica: 1965 Ford Mustang 5.0[/h]
Brentton Fuller
[IMG2=JSON]{"alt":"1965 Ford Mustang","data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/07\/s-l1600-3-29-e1564517949929-630x390.jpg"}[/IMG2]
Up for sale is this amazing, custom 1965 Ford Mustang that looks more vintage than it really is. The car is currently for sale with a current bid price of $4,050 with the reserve currently not yet met. It is located in Cambridge Springs, Pennsylvania. No mileage is listed nor is there a VIN, but the seller says the title is clear. You can view more information about it here on eBay.
[IMG2=JSON]{"alt":"1965 Ford Mustang","data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/07\/s-l1600-40-630x390.jpg"}[/IMG2]
Under the hood of this Mustang is a modern 5.0 that is connected to an unspecified automatic transmission. While the automatic might not exactly be good for track use, the car itself could be an incredibly reliable daily driver. There is no explanation by the seller of why the car has a newer engine or when the work was done. They also don’t mention if it was done by themselves or a shop.
[IMG2=JSON]{"alt":"1965 Ford Mustang","data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/07\/s-l1600-1-35-630x390.jpg"}[/IMG2]
Inside the car is slightly primitive. There are no door panels and the steering wheel is custom. It does need to be cleaned out, but it is functional. The seller does not have any information listed about it. It would be safe to assume it is not original based on the rest of the car, but you would want to clarify with the seller before making a bid. They suggest contacting them for more information.
[IMG2=JSON]{"alt":"1965 Ford Mustang","data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/07\/s-l1600-2-35-630x390.jpg"}[/IMG2]
This car looks to be quite a driver. The seller indicates that the car could be a perfect daily driver as well as be a show car. They also indicate that it could be a track car if so desired. Thankfully the car is said to be painted under the patina effect, so it could easily revert back to something normal if that is not your desired look.
More: Ford Mustang
More: Ford Mustang
