So at the end of the day, this is a very bad transmission for a mutli person truck.
I have some trucks driven by3/4 guys a week and someone different on weekends.
Trust me, as a guy who tries to get guys to drive a certain way each are different.
Personally I think engineers are getting to cute. Design it to shift where it should
and how its driven won't matter. this has worked fairly well for the last 40-50 years.
So leave it alone. How many vehicles are driven by husband and wife?
how many are driven often by both?
how differently do they drive?
Does Ford expect us now spend 120k for two trucks, so it only has one driver?
All great questions, answer not possible, simply because every household and business is different.
Not necessarily Trevor. Allow me once again.
In an effort to be brief yesterday, I overlooked another important feature.
In order to be an adaptive transmission, it is also a smart transmission.
That means it selects the best gear for the circumstances at any given time.
So it pretty much never shifts through all the gears successively and sequentially.
Let’s say from a stop or red light in traffic, once you pull away it may go 1st, 3rd, 5th and then 6th, 8th.
But at the next stop it may go 1st, 2nd, 4th, 6th, 7th, 9th.
Those folks that have a touch of OCD (that’s the term I should have used yesterday) can see this in the instrument cluster if they have the gear display activated.
Some of them start to worry that their transmission is not working properly and they then pay more attention to that then the road in front of them.
Again, they may try to replicate the condition to confirm their suspicions or they may try to change their driving habit to see if the transmission can hit all the gears consecutively.
They can’t, or they start to notice the transmission starting to gear hunt.
They come in with complaints too.
My transmission is not working properly. 3rd gear doesn’t work or something like that.
We again have to explain that it is not supposed to necessarily hit each gear consecutively.
Salesmen are supposed to explain this too at delivery.
It is a smart transmission, designed to use the best gear under the circumstances.
Is it a cold start or are temps warmed up?
Is it an aggressive launch or an easy pull away?
Is it an uphill grade, flat or slight downhill grade?
Are you loaded or empty?
Pulling a trailer or not?
Are you using premium or regular fuel?
Snow on road or dry?
The transmission will always try to be in the best gear for best performance and efficiency.
So if it determines that it is best served by a 2nd to 4th shift, that’s what it will do.
It is not malfunctioning. It is doing exactly what it was designed to do. And it will also do this on downshifts too, so be ready for it.
The best thing remains to drive it and forget it.
Or drive it like you stole it.
Those situations are trouble free.
Let me put it this way.
It is powerful and designed to work, so it likes to pull a load.
That is when it is happiest and working best.
So don’t try to interfere or think that you can outsmart it.
Just give it a load to pull and it will oblige.
To your concern Trevor, I would suggest don’ even think about it.
Let all the people that will drive this thing drive it the way they drive from day one.
It will adjust to that environment from the get go.
It’s not really behaviour. It’s algorithms.
I’m not an engineer but something like that.
It will always want to be in the best gear and it wants to pull.
Give it that without trying to outsmart it and it is happiest.
I can speak to a couple first hand experiences.
First, we have two 2019 F150’s in our rental/loaner fleet at the dealership. Both equipped with the 10 speeds and 5.0’s.
Those are always out being driven by different people from day 1.
They go out a lot because we have lots of truck customers, loggers, farmers and contractors.
When they bring in a truck they don’t want an Escape as a loaner, for example.
Both those trucks drive perfectly. No issues at all.
I would know as I drive them a fair bit to either deliver or pick up and to gas them up after each use.
Since they are rental/loaners, clients probably drive them like they were “stolen”.
Second is we have a large Road repair and Rail maintenance contractor as a client. They also contract flag persons for DOT, CN, Hydro and what not.
I can’t divulge their identity on here but suffice it to say that between all business lines they cover most of eastern Canada with several different employees.
They have an impressive fleet of 2018 - 2019 F150’s that travel all over and driven by different employees.
They have a mix of 3.5 and 5.0’s.
We see them in occasionally for maintenance or the common recent recalls for block heaters, seat belts and the like.
To my knowledge, there has not been one concern with transmissions.
The takeaway is that the people who just get in and drive are having trouble free experiences.
The clients that are reporting issues are those that are, for lack of a better description, looking for it.
Individuals prone to OCD, some ADD, nit pickers, people just prone to worrying about every little thing. Worry worts.
Like someone said earlier, it is no longer a mechanical or analogue world.
It is a digital world. Let the computer do it’s thing and it works.
Try to outthink or outsmart the computer and things unravel.
A good comparison to end on would be the use of a dual clutch automatic in the last generation Focus.
In tbeory, it should have been a hit.
And it likely would have if young adults from the tuner crowd bought them.
In reality, it was seniors on fixed income or young girls out of college and the like, all looking for maximum fuel economy because they had bills to take care of.
Not many or any young men bought that car.
The result was that owners drove extra conservatively to save fuel.
Complaints came in of balking transmissions, or shudder.
Of course, they had cars with race derived transmissions, meant to be driven spiritedly (if not beat on) but they were driving ultra conservatively. A bad scenario in the making.
The result was that the transmission got a bad rep.
In fact, it was not sold to the right consumer group.
Those that were driven hard had no issues.
In retrospect, Ford put that transmission in the wrong car.
Hindsight being 20/20 they likely would have done much better had they used it in an auto version of the Fiesta and Focus ST and even the Fusion sport. All of which are geared to more spirited driving.
There was a lot of work into the 10 speed by both Ford and GM and I think it is well suited to it’s current duties.
It is likely more “smart” than “adaptive”.
Saying that it adapts is basically the same as saying that it always seeks to be in the best gear for the given circumstances.
Just get in, drive and don’t think about it.
