Some more Coyote info I found later this evening
Edit note - only good up to gen 2 , gen 3 differences - see Marks info below!
PERFORMANCE DIFFERENCES
In terms of performance, the Mustang’s Coyote has more horsepower and the F-150’s Coyote has more low-end torque, hitting its peak torque at around 3,850 RPM instead of 4,250 RPM like the Mustang. Ford knew that this engine was going into a pickup truck and that it would be made to tow things, to go off-road, and in general, perform all of the duties people expect their trucks to be capable of.
Earlier F-150 and Mustang Coyotes also had a lower compression ratio, but that’s been changed for the third generation of both, which started in 2018. Now, you’ll get a 12.0:1 compression ratio in either Coyote, which means better fuel economy. The higher the compression ratio, the more power you’ll be able to achieve with less fuel.
COYOTE ENGINE COMPARISON
Engine | Horsepower | Torque | Compression Ratio |
F-150 First Gen Coyote | 385 hp @ 5,750 RPM | 387 lb-ft @ 3,850 RPM | 10.5:1 |
Current Gen F-150 Coyote | 395 hp @ 5,750 RPM | 400 lb-ft @ 3,850 RPM | 12.0:1 |
First Generation Mustang Coyote | 412 hp @ 6,500 RPM | 390 lb-ft @ 4,250 RPM | 11.0:1 |
Current Gen Mustang Coyote | 435 hp @ 6,500 RPM | 400 lb-ft @ 4,250 RPM | 12.0:1 |
MECHANICAL DIFFERENCES
Since there’s a performance difference between the F-150 and Mustang Coyotes, it’s safe to assume that there are several mechanical differences between the two that cause them to have different strengths and weaknesses.
The F-150 Coyote has a cast iron exhaust manifold in contrast to the Mustang’s stainless steel exhaust manifolds. Cast iron is strong but heavy, stainless steel is less strong but substantially lighter. This makes the F-150 Coyote more durable, but less fast than the Mustang. The stainless steel exhaust manifold is also more resistant to weathering and rust.
The stainless steel exhaust manifold is an important feature for the Mustang. When you’re in a pony car, you tend to ride lower to the ground, and that means more rain, road salt, and every other grimy thing that you encounter.
These intake manifolds all came out of Coyotes and they’re all very different.
The camshafts between the two are also different. The Mustang has long-duration intake cams while the F-150’s are substantially shorter. The earlier the intake closes the greater the cranking pressure, which is necessary for low-end torque.
Exhaust manifolds and camshafts can be easily changed, so neither of these should be deal-breakers, and if you were already planning on changing from your stock exhaust manifold to a set of
long tube or shorty headers, then buying an F-150 Coyote will save you some money.
The F-150 Coyote also has a front-mounted oil cooler, less robust oil pump gears, and no windage tray. The timing cover is less ribbed, and the alternator location is different as well. This is all to say that if you’re planning on doing other substantial performance enhancements, like a
supercharger installation, you will want to be very aware of this and evaluate the differences between the superchargers available for the F-150 Coyote as well as for the Mustang Coyote. Superchargers, in particular, have very specific requirements for where things are located and how much space they require.
This means that Coyote swaps with F-150-sourced Coyotes may require more fabrication as well since they aren’t designed for the Mustang’s engine compartment specifically.
