New blend door actuator arrived and has been installed. Working great. Installed hood struts and removed the prop rod. Kit from Amazon did not come with the proper fittings for the hood end, so I had to “MacGyver” a solution using some drilled metal plates, some taped on bolts, a couple of large washers, and some string to hold it all in place until it was tightened.
