So this is the first round of ordered parts, from Maximum motorsports
With all the delays, I have been told 8-10 weeks, they still hand build the
k-member. Gerry called and also on this order is a set of Bilstein shocks for is car also.
Even with covid pony express still works even if limited.
K-Member, 1979-95 with 4.6Lmodular or 2011+ Coyote engine
-1,2MM Front Control Arms, 1979-93,Non-offset (Stock Geometry)
-2Delrin Bushing Kit for MMFCA's
MM Front Control Arms, 1979-93,Non-offset (Stock Geometry), Delrinbushings
MM Caster/Camber Plates, 1990-
MMST-6MM Steering Rack Bushings,
MMK-Member-13MM Hybrid Steering Shaft,
Power rack,1979-93 w/ SN95 rack
-1MM Tie-Rod End Kit,
1979-93aftermarket K-Member (bolt-throughspindle). Fits standard-threads
-408-BLSway Bar End Links, 1994-04, Short
1-3/8" Universal Sway bar Bushings
MMFSB-51MM Front Swaybar Relocation Kit,1994-
MMFSB-60MM Front Swaybar BracketReinforcement Kit, 1979
10.310Eibach Front Swaybar, 1979-
MMFL-5PCMM Full Length Subframe Connectors,1979-04, Powdercoated
MM Panhard Bar Axle Mount, withhardware kit, 1979-
MM Panhard Bar Chassis Mount
MMPBAR-2MM Panhard Bar Aluminum Rod,Polished
MM Panhard Bar, 1979-93, Polishedrod
MMRLCA-50MM Rear Lower Control Arms, RoadRace, 1979-
MMTA-3MMTA2MM 'Heavy Duty' Torque-arm mainbeam
MMTAC2MM 'Heavy Duty' Torque-armCrossmember
-3Heavy Duty Torque-arm hardware kit(rectangular subframe connectors)
MM Heavy Duty Torque-arm,rectangular subframe connectors, 8.8"axle
MMRSBH-3... Weld-in Hardware Kit, adjustable rearsway bar
MMRSB-95Rear Swaybar arm kit for 1-1/4" bar
SB-013MM 1-1/4" x .095 wall rear swaybar,bar
MM Rear Swaybar, 1-1/4" x .095 wall,weld-in kit
KONI-48741-1121SKoni Single-Adjustable strut,
Koni Single-Adjustable shock,
1986-93V8 & 1994-04, solid axle
Set of four Koni SA shocks & struts,1987-93 V8 Mustang (no IRS)
MMCO-2MM Front Coil-Over Kit, fits Koni,Tokico, Strange, Lakewood struts
MMCO-5MM Solid-Axle Rear Coil-Over Kit,
KoniSport shocks, SA and DA
HYP35010... Hypercoil Coil Over Spring, 350 lb/in,10", 2-1/2" dia.267.97
HYP22509...Hypercoil Coil Over Spring, 225 lb/in,9", 2-1/4" dia.278.97
504-BLMotor Mounts, 1996-2004, 4.6 literengine, polyurethane
MMBAK-20Hydroboost Conversion Kit, 1979-93Mustang, 1999-2004 Hydroboost
