I was never a Fan of Renault, but this Model definitely has the Cool Factor.
[h=1]Rally Car Neglect: 1987 Renault 5 Turbo 2[/h]
image: https://barnfinds.com/wp-content/uploads/2018/06/renault-turbo-side-630x390.jpeg
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2018\/06\/renault-turbo-side-630x390.jpeg"}[/IMG2]
image: https://barnfinds.com/wp-content/uploads/2017/11/Jeff-Lavery_avatar_1510763369-24x24.jpg
By Jeff Lavery Just under 5,000 Renault 5 Turbos, or R5s, were built over a six-year production run. Their legendary turbocharged performance, aided by an impressive reputation on the world rally stage, made them icons before their production ended and quickly put them in collector car territory. Today, a clean example with set you back a fair amount and project-grade cars are rare to find given their revered status. This example here on eBay is a barn find with tired cosmetics, but still commanding an impressive £44,995 Buy-It-Now.
image: https://barnfinds.com/wp-content/uploads/2018/06/renault-turbo-rear-630x390.jpeg
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2018\/06\/renault-turbo-rear-630x390.jpeg"}[/IMG2] The rear end is perhaps one of the most recognized among 80s rally icons, with a widened rear section concocted by Bertone to accept the mid-engined turbocharged four-cylinder, clearly visible behind the driver and passenger’s heads and through the rear hatch glass. Performance was stirring, returning a run to 60 in about seven seconds and far quicker than the standard front-engined model with its modest fenders and wheels. As you can see, the cosmetics are fairly tired around all sides of the R5.
image: https://barnfinds.com/wp-content/uploads/2018/06/renault-turbo-roof-630x390.jpeg
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2018\/06\/renault-turbo-roof-630x390.jpeg"}[/IMG2] These are the details you just don’t see on a car typically squirreled away as a collector’s item. Similar in intent to the Pontiac Grand Prix Aerocoupe we recently featured, Renault offered this classic hot hatch in order to comply with Group 4 homologation requirements, which effectively gave buyers a rally car for the streets. In addition to the hotted up motor moved to behind the driver’s ears, the R5 was also converted to rear wheel drive, leaving little in place besides the cheerful nose to remind you of its economy car roots.
image: https://barnfinds.com/wp-content/uploads/2018/06/renault-turbo-interior-630x390.jpeg
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2018\/06\/renault-turbo-interior-630x390.jpeg"}[/IMG2] This is technically a Turbo 2 car, as these were made after the homologation requirements were met. The earlier cars are obviously more valuable, but the later examples also benefit from several mechanical changes that likely will make reviving this one a less expensive affair – namely, the high-end alloy components were replaced with stock Renault parts. Less exotic for sure, but performance didn’t suffer for it. The seller notes this example needs paint and although it doesn’t run, the engine does turn over. Since it meets the 25 year exemption, this R5 likely has appeal for shoppers both here and across Europe.
Read more at https://barnfinds.com/rally-car-neglect-1987-renault-5-turbo/#SJRWRc8cAjV5boT8.99
![Jeff-Lavery_avatar_1510763369-24x24.jpg](https://barnfinds.com/wp-content/uploads/2017/11/Jeff-Lavery_avatar_1510763369-24x24.jpg)
