This is the alignment print out.
Last year I had 1.4 neg. camber on left side and 1.2 on tight side.
I wanted to address this to have 1.4 on each side.
This was easily achieved with the Maximum Motorsport caster-camber plates.
The tech said they were smooth and worked well.
They moved easily to dial in the desired camber.
So easy in fact that he did not realize that they do caster and camber at the same time.
In his concentration to get the camber spot on he missed the fact that caster went up a bit on left side from last setting.
Up to 7.5 degrees from 6.9.
He is used to setting my 06 alignment and on those CC plates, the caster and camber adjust independently of each other by loosening different nuts.
He thought these were the same so he did not pay attention to caster.
I only picked up on it when he handed me the pictured printout once he was done.
He offered to re-do it but it was late and it is still all well within specs so I decided to try it out first to see how it was.
It drove quite well actually.
Responsive, so I’m good with it.
It’s staying.
