Motor:
- Diamond Pistons
- Stage 3 Comp cams
- Beehive Valve Springs
- Steel retainers
- MLS Head Gaskets
- ARP Head Studs
- LFP Dual Core Heat Exchanger
- BA2600 MAF
- 2.9 Polished Whipple
- 2lb crank pulley
- 3.5" upper pulley
Transmission:
- Spec Stage 3 plus
- Spec flywheel
- Ford racing 26 spline input
- MGW Orange Shifter
Fuel System:
- Return/Twin 255 Walbros
- 8 an feed
- 6 an return
- Fore fuel filter
- Fore Fuel Pressure Regulator
- 60lb injectors
Exhaust:
- BBK Long Tube Headers (chrome plated)
- BBK Off-Road X-Pipe
- Magnaflow cat-back exhaust
Wheels/Tires:
- 18" Staggered BOZE rims
- NITTO EXTREME DRAG: 305/35/ZR18 in the rear
- TOYO Proxes R1R: 265/35/18 in the front
Suspension:
- Eibach springs
- Kenny Brown Extreme Matrix Sub frame System
- Kenny Brown rear strut tower brace
- Bilstein Struts
- Maximum Motorsports CC plates
- Maximum Motorsports Urethane ISO's
Interior:
- Auto meter boost gauge
- Innovate air fuel ratio monitor
Exterior:
- Smoke head lights
- CDC light bar
- Black cobra letters bumper inserts
- Shorty antenna
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/i1070.photobucket.com\/albums\/u481\/psmithCA\/2003%20Cobra\/IMG_1988_zps3571568f.jpg"}[/IMG2]
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/i1070.photobucket.com\/albums\/u481\/psmithCA\/2003%20Cobra\/IMG_1987_zpse50bce89.jpg"}[/IMG2]
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/i1070.photobucket.com\/albums\/u481\/psmithCA\/2003%20Cobra\/IMG_1986_zps1dc5bdd7.jpg"}[/IMG2]
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/i1070.photobucket.com\/albums\/u481\/psmithCA\/2003%20Cobra\/IMG_1985_zps77639a6f.jpg"}[/IMG2]
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/i1070.photobucket.com\/albums\/u481\/psmithCA\/2003%20Cobra\/IMG_1984_zps8c1c33a7.jpg"}[/IMG2]
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/i1070.photobucket.com\/albums\/u481\/psmithCA\/2003%20Cobra\/IMG_1982_zps8feda4e1.jpg"}[/IMG2]
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/i1070.photobucket.com\/albums\/u481\/psmithCA\/2003%20Cobra\/IMG_1978_zps0894e33d.jpg"}[/IMG2]
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/i1070.photobucket.com\/albums\/u481\/psmithCA\/2003%20Cobra\/IMG_1977_zpscda9fe30.jpg"}[/IMG2]
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/i1070.photobucket.com\/albums\/u481\/psmithCA\/2003%20Cobra\/IMG_1975_zpsa14a3ad0.jpg"}[/IMG2]
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/i1070.photobucket.com\/albums\/u481\/psmithCA\/2003%20Cobra\/IMG_1972_zps37c10841.jpg"}[/IMG2]
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/i1070.photobucket.com\/albums\/u481\/psmithCA\/2003%20Cobra\/IMG_1970_zpsdff6b8d8.jpg"}[/IMG2]
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"http:\/\/i1070.photobucket.com\/albums\/u481\/psmithCA\/2003%20Cobra\/dyno_zpsc6f215f7.jpeg"}[/IMG2]
- Diamond Pistons
- Stage 3 Comp cams
- Steel retainers
- MLS Head Gaskets
- ARP Head Studs
- BA2600 MAF
- 2lb crank pulley
- 3.5" upper pulley
Transmission:
- Spec Stage 3 plus
- Spec flywheel
Fuel System:
- 8 an feed
- 6 an return
- Fore fuel filter
- 60lb injectors
Exhaust:
Wheels/Tires:
Suspension:
- Eibach springs
- Bilstein Struts
Interior:
Exterior:
- Smoke head lights
- CDC light bar
- Shorty antenna
