Thinking maybe the lowering of the car is not the problem (at least on its own). In a previous discussion I started Sept 30th 2019 titled "Bump Steer Kit -- a Good Idea?" (previous to any lowering) I was asking input on bump steer kits as a way to address the same issue. The question I asked was "My '02 GT Convertible tries to take control of the steering on our bumpy Island roads and I am wondering if a kit would help?". The next Spring I went from there to lower my car as a way to try to get it to handle better. Previous to that (early Sept 2019) I had installed a BBK Strut tower brace to tighten the front end...so maybe that is the culprit!
I mentioned bump steer as a possibility a few posts back.
That is usually an issue on aggressively low cars.
Check the angle of your tie rods when the car is on flat ground and suspension loaded with car’s weight. Refer to previous post for what to look for.
If it was acting up when car was still stock height, it likely isn’t bump steer.
General rule, a stiff chassis, plus stiff suspension and stiff tires is basically a race car, or the beginning of one.
It will be influenced by and follow the contours of the road more than a soft chassis, soft suspension and soft tires.
Like a roller coaster.
Will be influenced by more or less crown, more or less banking, more or less ruts, transitions and rough pavement.
Basically your car dates back to 1994 and the SN95. Chassis back then were not as stiff as today. Adding that strut brace likely contributed to stiffening it quite a bit.
Removing it would be an easy test.
Beyond that, we’re guessing.
So far, everyone that has posted has liked the changes from dropping their cars.
However, what is an improvement and acceptable for some may not be for others.
We all have varying degrees of acceptance or compromise.
I avoid rough roads too when I can.
From year to year, I make mental notes not to go back here or there.
It’s possible there’s nothing wrong and your car is behaving exactly the way it should with the changes you have made. Maybe the changes are too much for your liking.
Without driving your car to get a seat of the pants feeling, it’s hard to speculate any further.
I did notice on the first page of the thread you wrote you were happy with the changes after the lowering springs.
What changed between then and now?
Good luck with your search.
