thundr
Decided to make these so I can get the jack under car. My next task will be to take off the wheels for a detailed cleaning. I usually use a series of blocks. I hope these will be easier to get up about 3" or so.
I glued and screwed the boards together then cut with chainsaw on the bias. Had to plan the screws to avoid chain saw. In retrospect cutting prior to would be safer, but not a quick. Took 35 minutes from start to finish.
