15-22 Ford Performance adjustable strut mounts
glassguynb
Active member
I am looking to sell some ‘New Take-Off’ ford performance adjustable strut mounts. I purchased them to correct my alignment after lowering my car, but they don’t offer enough positive camber. Great for those that want track handling. Asking $400
I only lowered it 1” using the Ford Performance street handling pkg, but it put the camber just out of spec and after about 8k the inside shoulders are showing wear. I found a bolt kit from Eibach and rear camber kit from Steeda. Hopefully this does the trick. Have to wait until the snow is gone and I can get it back to the alignment shop.
Yes, the rear toe links do have a cam adjuster on them. Are you suggesting a bit of toe-in on the rear will help?
And adding toe in the rear also affects the total camber reading.
You can be aggressive with rear toe.
As much as 0.23 total toe is still within factory specs. So 0.11 to 0.12 each side.
In front, if you toe in, it will counter inside wear from negative camber.
You could go as much as 0.05 each side for a total toe of 0.1 in front.
This is counter to factory recommendation but is the biggest discrepancy that alignment shops overlook that can make a significant difference.
Factory specs call for straight ahead, 0.00 total toe in front, and that is what makes all of the tires on the front of these cars wear prematurely. Tire always rolling on inside shoulder.
All these cars come with negative camber from factory, which is mot adjustable.
Only toe is adjustable.
Alignment shops, in the name of doing a good job, dial all of our cars in at 0.00 total front toe.
That wears the tires but alignment shops says they can’t do anything else because it’s in spec.
They gorget or deliberately overlook what they should have learned when they took their training.
That is that toeing the front inward helps mitigate inner tire wear with cars that have negative front camber.
As a client, you have to ask for them to do that. I don’t know why.
Anyway, here’s a print of recommended settings from Ford Performance.
I agree with all except front toe for street setup.
We should all have a bit of total toe in in the front between 0.06 and 0.1 to mitigate inner tire wear.
This also applies to the S650 cars.
The whole suspension and steering is all carry over from S550.
Ahh ok gotcha. I have been eyeing Steeda progressives, you can out them in a full kit with camber plates, shocks, struts.....etc. Just not 100% if I want to drop just over an inch given our lovely roads lol
Be careful what you wish for.
The S550 and S650 cars are much lower from factory than all the previous generations.
They are very well sorted out from factory.
They do not need to be lowered much if at all.
My suggestion is to consider BMR or Steeda minimum drop springs.
BMR lowers rear 1/2” and front 3/4”.
Steeda lowers 1/2” all around.
If you are keeping equal diameter tires front and rear, then BMR work well because they bring back a bit of forward rake.
Have you noticed the cars in stock form are slightly higher in front.
If you are going with tires of larger diameter in rear than front. Similar to Bullitt, Mach1, PP, Dark Horse or Shelby, then Steeda may be for you as the tire diameter sizes will give you back a bit of forward rake.
Anything an inch or more lower is going to create compromises. Good for show cars or track cars but not so good for touring and easy maintenance. Hard to get on to lifts.
Look for Mike2021’s old posts on this site.
He lowered a 2021 Mach1 with Eibach pro kit springs, which also drop car 1.1” all around like the Steeda or Ford Performance.
It was too low and caused him grief all the time on runs.
He ended up going back to stock height.
Disclosure on my part.
I have the BMR minimum drop on my red 2015 GT, with equal diameter tires all around. Paired with Ford Performance track dampers.
I feel it’s the perfect height and stance.
Not slammed but a great handler and great look.
I have Maximum Motorsports caster-camber plates on all my cars to handle the camber.
Yes I had heard he had issues, but I thought that was from his Kooks headers which also hang a little lower than most.
