[h=1]Easy Restoration: 1968 Shelby GT500[/h]
Adam Clarke
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/11\/1968-Shelby-Cobra-GT500-1-e1573084197747-630x390.jpg"}[/IMG2]
This 1968 Shelby Cobra GT 500 is a solid car with no major rust issues. It will need a cosmetic refresh at some point in the future, but none of the work required would seem to be urgent. It is missing a few original parts, so the next owner will probably have some shopping to do if they wish to undertake a faithful restoration. The GT 500 is located in Fairhaven, Massachusetts, and is listed for sale here on eBay. The BIN has been set at $65,000, but there is the option to make an offer.
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/11\/1968-Shelby-Cobra-GT500-2-630x390.jpg"}[/IMG2]
The Shelby is finished in Wimbledon White and presents quite well. The owner provides detailed photos of the car’s underside, and it would appear that it is as solid as a rock. There is some rust visible in a couple of spots around the car, but it doesn’t appear as though any of this is horrendous. There is some in the rear quarter panel on the driver’s side, along with a spot in the trunk close. The rest of the car looks to be decent, and it does continue to wear all of the distinctive Shelby fiberglass pieces. There are a few dings and marks there, but these could be addressed when the rust repairs take place. One thing that is missing is the distinctive Shelby wheels. This is disappointing, but a search has revealed that a set of these can be secured for around $1,200. Given the wheels that are currently fitted to the car, I can’t help but feel that this would be money well spent.
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/11\/1968-Shelby-Cobra-GT500-3-630x390.jpg"}[/IMG2]
The interior of the GT 500 is complete, and while it generally looks very good, it certainly wouldn’t satisfy the perfectionists out there. The majority of the interior trim looks good, although there are a few pieces of trim in the rear of the car that has been marked over the years. These may be able to be restored, and if the view is to try to maintain as much originality as possible, then it would be worth the effort. The driver’s seat also looks like it either has a tear or a seam separation, so this will also need to either be repaired or replaced. Interestingly, the tongues for the harnesses both appear to have a significant amount of surface corrosion on them, which is an interesting development when you consider just how little corrosion there is across the rest of the car. The rest of the interior looks pretty reasonable, with no signs of cracks or splits in any other items. The Shelby was also originally optioned with air conditioning, but the compressor is now missing from under the hood.
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/11\/1968-Shelby-Cobra-GT500-4-630x390.jpg"}[/IMG2]
It was what was under the hood that really made the GT 500 special, and that was the 427ci V8, producing a conservative 355hp. In this case, the car also features an automatic transmission, power steering, and power brakes. The owner does say that the engine is excellent, but he also says something else about it. The 427 that you see isn’t original. In fact, he says that it is dated as a 1964 engine. That’s a blow because a lack of numbers-matching status will negatively impact the car’s value. Just how much can tend to be a bit of an open question.
[IMG2=JSON]{"data-align":"none","data-size":"full","height":"390","width":"630","src":"https:\/\/barnfinds.com\/wp-content\/uploads\/2019\/11\/1968-Shelby-Cobra-GT500-5-e1573084224384-630x390.jpg"}[/IMG2]
This 1968 Shelby Cobra GT 500 shows a lot of promise, and it does appear to be a solid and clean car. The cosmetic work that would be required to bring its appearance back to a high level would be neither particularly difficult or very expensive. If it was a numbers-matching car, then a six-figure value would be easy to achieve, but all things considered, I believe that the price that the owner is asking is probably close to the mark. What do you think?
More: Ford / GT500 / Shelby
