Battery Maintenance
thundr
I am sure we all had to replace a battery or two over the years. It's crappy when you are stuck and have to replace it in a pinch cause you're stranded.
I replaced mine a few years back, the original only lasted 5 years or so. It seems the life is based on your maintenance, especially for cars that sit for the winter. I put the car on the trickle charger for the winter. The one I have is a electronic type that goes through a bunch of cycle to de-sulphate the plates, or something like that. Not much of a sparky so if anyone has more insight chime in.
Of course there are other types of batteries too, AGM and those yellow top Optima one. These are more expensive too.
I wanted a match to the stock type so I got a ford replacement.
Here's my question, is there a way to test a battery to see what the status is.
The best way is to put a fully charged battery on a load tester and see how it performs. Sangsters a local parts store, which is where I get my batteries, will test them for me if I'm suspicious of one
thundr;n1744 said:
Good to know, I have a few deep cycle batteries to check, I wonder if the test procedure is the same. I'll check it out.
Diesel auto & electric will test them for free also.
Thunder
I can access a couple of different testers through work that we could use at your home. The old faithful carbon pile load tester that requires a charged battery and / or a new electronic load tester, does 2 load cycles, watches recover time , and calculates good / recharge / junk status on even batteries that are not fully charged. Let me know if you want to try these options!
05 gt 5spd;n1839 said:
Thunder
05 gt5spd,
That sounds great. Let me know how and when. No rush either.
Canadian Tire will test them for free too.
Everyone laughed at me when I bought a 25$ extended 9 years warranty on my battery 7 years ago. Last year I got a brand new one for free when mine died :D
